Best Buy Co, Inc. Buy Used Saws CCC Ebay Store HLSupply Daily Deals
Building a mill.
Discussion in 'Milling' started by Wagnerwerks, Jul 10, 2018.
  1. Wagnerwerks
    Wagnerwerks I have yet to "suffer" from CAD
    2,177
    6,327
    378
    Pa
    This is going to be a standard Wagner thread with rediculously long spans of time between posts. :)
    I started collecting for my small engine driven chain mill. I have to find some metal yet, but most of it is already laying around here in my mess. Here's the start... 20180709_213503.jpg 20180709_225706.jpg
    It's not much, but I have a lot of the odds and ends gathered too. I have pullys and either an electric or centrifugal clutch to drive the chain. I'm going to use a jack shaft with a rim drive sprocket center on a turned shaft end to hold the drive rim. I plan to set it up much like a Norwood's mill with the motor riding on a track beside the log. It should be easy enough to make the depth adjustment work. I don't know the guy on YouTube that built one sort of like this, but his trial and error helped me come up with the plans in my mind... Lol
    More to come.... A long time from now...
  2. dustinwilt68
    dustinwilt68 Destoyer of crankshafts
    Mar 8, 2016
    4,089
    17,147
    393
    Southwest PA
    Looking like a great start Kris.
    PA Dan likes this.
  3. angelo c
    angelo c Larger Member
    2,048
    7,937
    383
    Good on ya Kris....
    Some day when I get big, I'm gonna get me a saw mill. My mommy says I'm too small right now and I should stick to playing in the sand box .
    PA Dan, hseII, ajschainsaws and 5 others like this.
  4. Sty57
    Sty57 Jon1212 Approved!
    Jan 6, 2016
    6,344
    39,662
    510
    Land of Cheese & Beer
    Just don't eat any of them chocolate bars you find in the sandbox............
    PA Dan, hseII, ajschainsaws and 6 others like this.
  5. quietfly
    quietfly Pinnacle OPE Member
    536
    1,950
    208
    Northern NJ
    ooooohh looks like it should be fun!!!!!
    PA Dan and ajschainsaws like this.
  6. quietfly
    536
    1,950
    208
    Northern NJ
    i'll be waiting with baited breath
  7. Wolverine
    Wolverine Do you even burn wood bro?
    4,082
    16,677
    408
    Where freedom was won
    Guess I better get the big bag..
    [​IMG]
    PA Dan, AlfA01, Semotony and 5 others like this.
  8. Lightning Performance
    Lightning Performance Pinnacle OPE Member
    Jan 26, 2016
    2,837
    5,043
    290
    Any drawings? On a napkin will do...
    PA Dan, ajschainsaws and Semotony like this.
  9. Wagnerwerks
    2,177
    6,327
    378
    Pa
    I'll find the link to the one I'm copying...
  10. ajschainsaws
    ajschainsaws Axes never run out of Gas
    Jan 26, 2016
    3,956
    15,197
    408
    South west UK
    Great thread it’ll be good too watch this come together
    I’ve starting building a trailer mill ,it will be interesting
    Too see what your doing on the frame and how your
    mounting the engine and what your using for a chain tensioner
    PA Dan and Lightning Performance like this.
  11. Wagnerwerks
    2,177
    6,327
    378
    Pa
    This guys frame is where I got a few ideas, but I'm still leaning toward the Norwood's mill style with the track sitting beside the log. It really opens up a lot of cutting options for odd shapes and different size logs. I can't decide if the bar will need the support if it's 36". Norwood's recommends I think a 24-8" max. I assumed that was for avoiding sag.
  12. Wagnerwerks
    2,177
    6,327
    378
    Pa
    here's the demo video of the Norwood's mill. The biggest negative is the ladder is too flimsy for a track. The next is the $1200 chainsaw... Not that I don't have mill saws, but the Briggs will have benefits...
    I'm not sure about the lift system, but I'm leaning toward this guys style... Screenshot_2018-06-13-22-58-44.png
    Some guys use cable winches, but that seems too eh to me...
  13. ajschainsaws
    Jan 26, 2016
    3,956
    15,197
    408
    South west UK
    The engine mounted like that in the photo is what I’ve been thinking of rather than a saw fixing it with a bar adjuster is the next hurdle
  14. Wagnerwerks
    2,177
    6,327
    378
    Pa
    I'm just not seeing the issue there. Have you ever seen the old saws with bar mount and adjuster? You could even use an old clutch cover.
    ajschainsaws likes this.
  15. Wagnerwerks
    2,177
    6,327
    378
    Pa
    Are you talking about the height adjustment or chain tension?
  16. ajschainsaws
    Jan 26, 2016
    3,956
    15,197
    408
    South west UK
    Yes the chain tensioner I’ve got the height adjuster and frame sorted and 75% put together
    Wagnerwerks likes this.
  17. Wagnerwerks
    2,177
    6,327
    378
    Pa
    I'm going to use a jack shaft to a plate. My drive rim will be mounted to the shaft and the bar will bolt to the plate. I was just planning on using a normal chainsaw style setup on the plate that bolts the bar down... I'll try to find a pic or draw it or just build that part soon. I'm in the process of switching jobs/starting my own business so time is limited, but that's really nothing new here :)
  18. Lightning Performance
    Jan 26, 2016
    2,837
    5,043
    290
    That mill seemed as fast as free hand or as an alaskan type mill. Slow but steady.
  19. Wolverine
    4,082
    16,677
    408
    So Kris, just thinking out loud here.. if you're going this far, why not run a band instead? It's much quicker, no bar oil, less waste, the list goes on. Check out the vids (a whole series showing the build):
    ajschainsaws and Rob Stafari like this.
  20. Wagnerwerks
    2,177
    6,327
    378
    Pa
    I looked at it a lot and you are totally right, but I have almost everything to build this and it has advantages for just milling slabs and wide crotch chunks. One other thing I thought about is the rails will work if I build a band mill at a later date. If the stuff I'm doing takes off, I'll likely buy a used band mill and just sell this one or repurpose it.
Loading...
Share This Page
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
