Buy Used Saws CCC Ebay Store
Building a Garage
Discussion in 'Construction' started by Marshy, Sep 4, 2018.
  1. J.Walker
    J.Walker Super OPE Member
    Jan 26, 2016
    113
    508
    158
    Bristol, NY
    Don't have alot to show yet.
    I've spent more on site prep, drainage and gravel than building materals so far.
    chipper1 likes this.
  2. chipper1
    chipper1 Here For The Long Haul!
    Jun 25, 2016
    3,510
    10,077
    393
    Grand Rapids Mi
    Well we need pictures when you do :).
    I'm guessing you will quickly run past once you start getting all the materials around$$$$$.
    I did most of that last yr, waiting a bit for the permit/materials.
    Semotony likes this.
  3. Marshy
    Marshy WFO Cutting
    Jan 5, 2016
    3,222
    10,454
    383
    Mexico NY
    Good advice. I ended up holding off for now on a garage. I will build one but starting something like that in September is not a wise choice. It feels like it's been raining the last 5 weeks and I still haven't finished a 24' lean-too for my firewood. Doubt I'd get very far in a garage doing it myself.
    Semotony, Cat 525 and chipper1 like this.
  4. Johnmn
    Johnmn Pinnacle OPE Member
    Feb 18, 2016
    1,800
    5,728
    340
    Minnesota
    Any questions I'd be happy to answer, I believe there is another contractor on here too but I don't remember.
  5. Marshy
    Marshy WFO Cutting
    Jan 5, 2016
    3,222
    10,454
    383
    Mexico NY
    Thanks man. I will for sure have some questions. I've actually been doing some research on pole barns and because I plan to build a horse barn and have a hay loft I was thinking about pouring sono-tube footers for the poles and using a wet-set column bracket.
    Semotony and chipper1 like this.
  6. chipper1
    Jun 25, 2016
    3,510
    10,077
    393
    Grand Rapids Mi
    Did you see the one that was in that one guys vidjas on YouTube, think I've seen you in his comment section before.
  7. Marshy
    Marshy WFO Cutting
    Jan 5, 2016
    3,222
    10,454
    383
    Mexico NY
    I dont recall making many comments on pole barn videos but it's possible I made one. One I watched augured 12" holes, poured concrete in sonotubes, used a laser to place the wet-set brackets all the same height, then built the wall on the ground. Then he lifted the whole wall with a skid steer that had a boom pole attached. An entire 40' wall went up in one lift! Slick as *s-word.
  8. chipper1
    Jun 25, 2016
    3,510
    10,077
    393
    Grand Rapids Mi
    I was just saying I thought I saw you on a logger wade video before.
    Here's the video I was thinking of, at 6 min or so you can see their new barn, maybe there's something better about it in another one, don't watch them all.
    Post a link to that video, I'm still waiting for mine yet, one day...
    Semotony and Cat 525 like this.
  9. Viper21
    Viper21 Super OPE Member
    Jan 13, 2016
    93
    394
    113
    Virginia
    I agree. Footings, & foundations are never bad places to spend a few extra bucks if possible.
    I started my own garage 2 yrs ago. I did a full 3 blocks above my floor (8" block). I then built an 8' wall (2x6) on top, & ended up with 10' ceilings.
    [​IMG]
    I don't plan on moving again so, the extra cash for this type of construction made sense for me. My next move will be to the cemetery.....
  10. KiwiBro (deleted)
    KiwiBro (deleted) Pinnacle OPE Member
    Feb 19, 2016
    532
    1,600
    203
    New Zealand
    You guys ever used or seen Cupolex domes over there?
    https://cupolex.ca/structural-slab-forming-solutions/
    interlocking plastic domes that form the sub-slab and foundations and work as an alternative to rib-raft/floated slabs.
    Minimal concrete but still good strength, while being fast and easy to construct.
    Did my first on a shed slab for parents about 10 or so years ago as one of the first in NZ to use it. Has worked out very well for them.
    dieselfitter, chipper1 and huskihl like this.
  11. huskihl
    huskihl Sausage Fingers Forever
    13,729
    77,322
    578
    Never seen it here.
  12. chipper1
    Jun 25, 2016
    3,510
    10,077
    393
    Grand Rapids Mi
    How deep do you have to have footings/post up your way. Last I knew we were at 42" here.
    Semotony and Viper21 like this.
  13. Viper21
    Jan 13, 2016
    93
    394
    113
    Virginia
    WOW...! That's deep !
  14. huskihl
    13,729
    77,322
    578
    42 in clay. Antrim co is 24 in sand, charlevoix county is 32 in sand
  15. chipper1
    Jun 25, 2016
    3,510
    10,077
    393
    Grand Rapids Mi
    Gets cold here, I'm more surprised at the requirements at Kevin's place, it's a lot colder up there.
    That's interesting. I wonder if it's that way here but everyone just goes for the 42".
    The spot I cleared is mostly gravel/sand.
    Semotony and huskihl like this.
  16. huskihl
    13,729
    77,322
    578
    There's more sand up here, so it's more common. It could be like that down there, not sure
    Sty57 and chipper1 like this.
  17. Johnmn
    Feb 18, 2016
    1,800
    5,728
    340
    Minnesota
    I'm in 60" country here guys.
  18. chipper1
    Jun 25, 2016
    3,510
    10,077
    393
    Grand Rapids Mi
    Dang :eek:.
    I may do frost walls on the short sides(height wise, both lean toos) then build a 6" wall on top as one will be insulated and the other I will most likely have a short wall pored since it's a bit into a hill and it will need the footings anyway. I may end up with them all the way around as I don't want different degrees of settling on the gable ends. What I don't want is to have to cut concrete or black around my door openings, but I'll cross that path when I have another 5k set aside lol. It is good to keep looking around/getting advice now though.
  19. KiwiBro (deleted)
    Feb 19, 2016
    532
    1,600
    203
    New Zealand
    Good point. Zero frost heave in the top third of NZ. Do you guys always have to get below the frost line, or can you just stop significant moisture getting under the slab/footings?
  20. huskihl
    13,729
    77,322
    578
    Have to be below it
    cus_deluxe, Viper21, chipper1 and 2 others like this.
Loading...
Share This Page
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
