Adamski
Plebus Splederns
- 2:53 AM
- May 3, 2017
- Essex, UK
I did a 44mm (260) the other day, I didn't take as much out, I just took the lip out/carried on with the same taper. I guess it it will flow better than it did but how much idk.
Yeah I questioned my logic but then I decided all 038 top ends use the same case so a mag cylinder may benefit with a little more volume. And a little more crank case volume may decrease top end power but may improve low end when buried in big wood. Which is all that I want from this. I’ll see. Either way the lower transfer needs tidying up as my burr is knackered and will not cut through the plating nicely using the tip of the burr. I don’t think the material removed is as drastic as it looks, bevel was around the yellow line originally. But then again I’m not sure if this was the correct approach.. well see..
