- 9:49 PM
- Feb 5, 2016
- Glenside Pa.
I just picked up a very clean low hour br600 with the 4 mix engine. Guy said it didn't run I got it home and put fresh fuel in and it popped off but wouldn't really idle. I need a little help on where to set the mixture with the limiters removed (spec?) I imagine that it's quite different than a 2t.
The carb. had limiters on it so I adjusted them to spec. 3/4 out and the threads felt very loose and the low screw fell out. It looks like someone was in fooling around so I removed the limiters. I found the hi screw 9 turns out and I'm guessing the lo was about the same since it took a little over 8 turns to seat it.
And yes I'm adjusting the valves as we speak.
Edit: I adjusted the valves which were definitely tight and set both screws at 2 turns out. It seems to run pretty good there smells a little rich at idle but burns clean wot. I only ran it for 30 seconds though because I don't want to kill it. Any advice would be appreciated.
