Buy Used Saws CCC Ebay Store
Block wall joint leaks water
Discussion in 'Construction' started by Marshy, Oct 30, 2017.
  1. Marshy
    Marshy WFO Cutting
    Jan 5, 2016
    3,172
    10,190
    378
    Mexico NY
    I'll get pictures tonight.
    What I have is a retaining wall built off the corner of my house foundation (also block). The joint where the two come together leaks a little ground water when it rains. I was wondering of there is a way to seal this joint. What product would I use?
    The purpose for sealing it is I built a small boiler room and it now leaks ground water into the room.
    I was thinking maybe I can drill holes up the crack in the seam and inject some low expanding foam (like Great-stuff) into the joint. Is this a good or bad idea?
    Any advice other than French tile? I would do that but only have about 3' of head room because the ground is under a 18x30 deck...
  2. thomas1
    thomas1 ┌∩┐(◣_◢)┌∩┐
    830
    4,533
    350
    Cristobal Colon
    The water is going to seek the path of least resistance. If that path is towards the face of your wall, that's where it's going. If you don't get the water out of there the freeze/thaw cycles will probably end up wrecking your wall. They make several different clear sealants, but they're not 100% effective and they're not going to seal any cracks.
    Do you know where the water is coming from? If it's only when it rains, may it be as simple as redirecting one of your downspouts?
    kkemp, Moparmyway, hseII and 4 others like this.
  3. junkman
    junkman Crush it
    Jan 3, 2016
    4,192
    16,153
    446
    pacific northwest
    Try cutting the crack with a 4 1/2 inch angle grinder to open up the crack with a concrete cutting blade ,they are metal usually with diamond grit glued on ,then pack with hydraulic cement ?
    this stuff expands and makes a water tight seal .
    [​IMG]
  4. Armbru84
    Armbru84 Here For The Long Haul!
    Jul 14, 2016
    1,099
    5,637
    392
    Michigan
    I am in essentially the same exact situation. I have a deck overhead even...I tried a few different sealers and even dig down outside and re-tarred the joint. That made the biggest impact but it still leaks now and again. Will be spending the money to do it right I believe.
    stihl saws likes this.
  5. srcarr52
    srcarr52 We can't stop here, th1s is bat country!
    Jan 12, 2016
    1,992
    11,957
    445
    Iowa City
    Fix the grading, maybe find someone to do a bentonite injection.
    I had a crack that was leaking in my poured basement and I had Kane Waterproofing come epoxy it and inject it with urethane and it seems to be holding up well.
    hseII, Dub11, stihl saws and 3 others like this.
  6. Marshy
    Marshy WFO Cutting
    Jan 5, 2016
    3,172
    10,190
    378
    Mexico NY
    I work with a guy that has a side business doing spray foam and he also does slab leveling. He probably has something to inject that will seal it. Never heard of bentonite.
    Just looking for something short term right now. I dont have time before winter to entertain any type of tile drain. All my down spouts go to a preimeter drain but the soil under the deck is sloped towards the retaining wall and has no grass. Any tile drain on the back side of the wall would have to be hand dug in a 3' high crawl area under the deck. It might be the permanent solution but would have to wait.
  7. Marshy
    Marshy WFO Cutting
    Jan 5, 2016
    3,172
    10,190
    378
    Mexico NY
    Here is a pic. The corner of the house foundation is black. The joint is only about 5' tall and only leaks from the bottom 10-12". Maybe one other damp spot 2.5'off the floor...
  8. Cracker Boy
    Cracker Boy Fl cracker
    May 31, 2016
    4,313
    7,586
    320
    Florida
    Spray foam in a can retains water.id recomend not doing that.also termites eat it
  9. Marshy
    Marshy WFO Cutting
    Jan 5, 2016
    3,172
    10,190
    378
    Mexico NY
    I thought great-stuff was closed cell foam so it will basically create a water barier... I know it's not intended for that purpose, just the concept of being able to spray an expanding sealer into a void and get it sealed.
  10. Cracker Boy
    May 31, 2016
    4,313
    7,586
    320
    Florida
    Marshy likes this.
  11. Marshy
    Marshy WFO Cutting
    Jan 5, 2016
    3,172
    10,190
    378
    Mexico NY
    I have a 4.5" concrete saw for an angle grinder. Going to stop at Lowes and see what they have for material.
    We just got about 2" of rain the last 48 hours so it's not a terrible leak considering how much it rained. Still more water than I want in my boiler room. It will get under my 2x6 wall I built and cause issues. I'm not too worried about the retaining wall, it's probably been like that since I've owned the house. I'll fix it, just not an immediate concern. Getting my boiler in is first.
    Cracker Boy likes this.
  12. concretegrazer
    concretegrazer Pinnacle OPE Member
    1,792
    6,420
    345
    Mo
    The hydraulic cement will do what your after. I use it in the bottoms of tire waterers.
  13. stihl saws
    stihl saws You can always justify another saw.
    1,300
    3,311
    293
    Virginia
    I'm dealing with a similar problem at my real job, school maintenance It looks like we're going to have to excavate around the 1954 foundation and find the problem. I see me running a track hoe soon.
    junkman likes this.
  14. Marshy
    Marshy WFO Cutting
    Jan 5, 2016
    3,172
    10,190
    378
    Mexico NY
    Take a look at that bentonite injection before you do, it might work perfect for you.
  15. Marshy
    Marshy WFO Cutting
    Jan 5, 2016
    3,172
    10,190
    378
    Mexico NY
    I'm going to give it a try. $8.50 for 10#. Worth the gamble.
    Moparmyway likes this.
  16. stihl saws
    1,300
    3,311
    293
    Virginia
    Thanks. That could be a option. My biggest problem is only about 3ft below grade, so we'll see what's in the budget.
  17. thomas1
    thomas1 ┌∩┐(◣_◢)┌∩┐
    830
    4,533
    350
    Cristobal Colon
    Boiler room is the white door?
  18. thomas1
    thomas1 ┌∩┐(◣_◢)┌∩┐
    830
    4,533
    350
    Cristobal Colon
    Nevermind, boiler room framing is nailed to the existing wall, correct?
    Marshy likes this.
  19. Marshy
    Marshy WFO Cutting
    Jan 5, 2016
    3,172
    10,190
    378
    Mexico NY
  20. thomas1
    thomas1 ┌∩┐(◣_◢)┌∩┐
    830
    4,533
    350
    Cristobal Colon
    Does that boiler take up the entire room? If you have the floor space, maybe just put a sump in, next to the wall, and run a small pump.
    Moparmyway, stihl saws and huskihl like this.
Loading...
Share This Page
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
