Does anyone have any experience with this item or have used it? I believe it also went by Industrieklebstoff adhesive technology. Maybe someone else knows a better plastic glue "that works" I am all ears.
Old thread but, I keep a tube of IPS Weld-On glue around here. It is a clear, thickened cement designed for acrylic sheet (plexiglas). It will "weld" quite a few plastics. Indispensable. I just test in an inconspicuous area with a dab. Let it sit for a few and scrape it off with a toothpick. If some of the color of the plastic your trying to glue comes off with it, your good to go. It can be a pain to work with. It skims over quickly. Because of this I'm always cleaning the end of the tube out with a toothpick! It's great for repairing cracks. Since it skims over quickly, it's less likely to run.
