Briggs 9 CI engine block. 3.5 HP
Could for any these engines or that what the 260224 crankshaft that it has was use in. Of course you need to check each of these for each had the extended camshaft.
· 092592-0166-99-->Cylinder,Sumps,Piston,Mufflers
· 092592-0204-99-->Cylinder,Sumps,Piston,Mufflers
· 092592-0219-99-->Cylinder,Sumps,Piston,Mufflers
· 092592-0642-99-->Cylinder,Sumps,Piston,Mufflers
· 092596-0199-99-->Cylinder,Sumps,Piston,Mufflers
· 092596-0648-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-0043-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-0153-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-0162-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-0164-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-0169-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-0180-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-0183-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-0252-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-0266-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-0267-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-0312-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-0331-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-0332-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-0364-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-0543-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-0544-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-0642-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-0714-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-0752-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-0762-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-0905-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-0914-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-0930-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-0931-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-0937-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-1026-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-1145-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-1175-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-1227-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-1277-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-1343-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-1347-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-1419-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-1571-99-->Cylinder,Sumps,Piston,Mufflers
· 092992-5043-01-->Cylinder,Mufflers,Piston Grp
· 092996-0154-99-->Cylinder,Sumps,Piston,Mufflers
· 092996-0190-99-->Cylinder,Sumps,Piston,Mufflers
· 092996-0341-99-->Cylinder,Sumps,Piston,Mufflers
· 092996-0648-99-->Cylinder,Sumps,Piston,Mufflers
· 092996-0763-99-->Cylinder,Sumps,Piston,Mufflers
· 092996-0859-99-->Cylinder,Sumps,Piston,Mufflers
· 092996-0932-99-->Cylinder,Sumps,Piston,Mufflers
· 092996-1177-99-->Cylinder,Sumps,Piston,Mufflers
· 092998-1573-99-->Cylinder,Sumps,Piston,Mufflers
· 093592-0543-99-->Cylinder,Sumps,Piston,Mufflers
