Homemade
- 10:06 PM
- Apr 8, 2017
- Wisconsin
What do you guys for assembly oil on bearings, piston skirts, rings and so on? I’ve used straight 2cycle oil. I know it won’t harm anything and will burn off cleanly. On four cycle engines I’ve seen everything from 5w30, to grease, to royal purple engine assembly lube.
I would not think the specific assembly oil would be needed for a saw?
The argument for the grease was that it will last longer during start up and provide better initial lubrication.
The 5w30 guys say the oil will last long enough and will not cause oil starvation when the grease washes off and plugs the oil filter.
Should consideration be given for needle bearings vs roller ball bearings to what kind of lube they get?
