- 9:47 AM
- Jan 3, 2016
- West of Kansas City
So has any one tried any of this chain. here are some pictures
Shopping for some chain saw it on eBay.Where did you find those?
I use quite a bit of it for customers who come in with ms170's and 180's who can't sharpen for **** and want a couple of low cost chains that will last them the year.
3/8LP .050 is the only one I've used mind, but doesn't seem bad for the price.
Would I run it on my own saws? No probably not, but I have the luxury of a lot of cost price bulk reels that most saw users don't
Maybe you should consider converting some of this to ripping chain.......at least until you're clear of those six inch spikes in that tree you're milling.
Very generous offer, Joe.You should have said I'd have sent you a loop for nothing if you paid postage! I'll extend this offer to the first 3 people wanting to try this chain on anything up to a 16" bar
So is it chisel or semi? Or is that what you meant by the tight radius- still round, but not quite full chisel? Looks like decent stuffMailman brought my new loop of chain this afternoon. After dinner I decided to put it on the saw and give it a go. These are my initial thoughts and findings on the Archer brand chain:
Taking a look at it, the teethe were ground and sharp. I put a .025" raker gauge on it and could not touch a raker. Put an .030" and could, so raker height was good. Rivets did not seem too loose, or too tight. Drive links are grooved for oil retention. Raker shape was a little different in that it swooped forward like most modern rakers do, the top is flat instead of coming to a point. Looks like when you take them down and don't re-profile them. This I liked to see. It was getting pretty dark by the time I got the loop on and the saw fired up to make a test cut. Comparing it to the freshly ground and .025" raker Stihl green label Picco chain, I'm going to say the Archer did cut a bit faster and was very smooth cutting, straight out of the package. To start with the Archer is a non safety chain while the Stihl is. The log tested in is only 10" or so in diameter, so chip clearance should not have been a major factor, the biggest difference I could see was the tooth design, The archer was much tighter with the radius than the Stihl tooth.
What I did not like about this chain was more about the packaging than the chain itself. Tooth design is not given at all. Also no sharpening angles are provided. Once the container is opened it can not be reused to keep a spare chain in. While none of these things are a big deal to me, it may be to someone else, like Joe Home Owner for example.
To summarize overall my first impression is, I like this chain. Think I will order some 3/8" that I'm more familiar with and give that a go too. Obviously more cutting time will be necessary to make a thorough evaluation, once fully vetted I think for the price this will be a nice chain to have plenty of loops around handy like. Just happen to have a good sized Maple down to do some independent laboratory testing on. More to follow.
