peter92
- 7:01 PM
- May 19, 2016
- maryborough qld aust
That part number is for 7 tooth, http://coonasawchain.com.au/shop/item/gbj9l7 but then theres this one http://www.ebay.com/itm/Rim-Sprocke...-Tooth-Standard-7-Spline-GBJ9L7-/121605151251I hope you find that it is big enough for you, just remember chainsaw mill shortens a saws life.
For a sprocket, should be a standard spline rim sprocket on saw not spur?
For a 9 tooth rim from gb, part number should be
GBJ9L7
I buy ordinary chain and grind the tooth angle from 25/30 down to the 10° I mentioned. Semi skip is not a bad idea.
im hoping to have a 056 to rebuild , that should be big enough
Can i run a 9 tooth on the 757
Peter
