Trevj1
- 3:13 AM
- Apr 1, 2016
- Interior BC
Wore North, MSA, and 3M half and full face masks for work.
Found North the most comfortable, was wearing it 6-7 hours a day sometimes.
If you can source the OV cartridges cheap enough, chuck a particulate filter over the end and have at. If you are not made of money, a good particulate filter is going to be really decent filtration. Be aware that te OV cartridges have a finite life, whether in use or not.
Aside from comfort (because it's not really a motivator to wear it if it isn't comfortable) fit for leakage is pretty important. Not much point in spending on cartridges, when you end up sucking fumes around the edges.
Personally, I am a lot surprised that there are not a bunch of masks available with a mouthpiece like a snorkel for swimming has, to be able to breath filtered air whether the beard is stopping the seal or not.
Another option to look at is the low profile, remote filter units designed for use by welders. Made to fit under the welding headgear, usually battery equipped with forced air, with the battery and filters worn at the waist and behind the user.
