redline4
I'm huge in Japan
- 9:03 AM
- Mar 12, 2018
- Rosholt Wisconsin
Being at a GM dealer, I wont be much help as the only non GM stuff I see is the used stuff the other wimmin I work with are afraid of.
I can help with some pics though.
Exploded view of engine.
It appears similar in many ways to the Generals 3.6.
Drain the oil first. Once you get the front cover and pull the pump, coolant will fill up the pan. If you dont drain it first, it will overflow and create a bigger mess.
Then drain again after job is done.
Pump bolt torque according to shopkey is 76-101"lbs.
