Do you usually sharpen the big or little end?3 teeth missing on a chain that's on its last sharpening. Major problem here folks, firstly I'd start a thread to get multiple opinions so we can all comfort you in the is time of need....yes add a voting poll to collect data too. This thread describes perfectly why men are no longer made like they once were. In the time it took to post up this thread you could have found a stick, sharpened its end with your pocket knife & poked it straight into your eye.
I was lying in bed thinking about this exact question when I thought perhaps my feet were hanging out the end of my bed, so out i got too take a look.Do you usually sharpen the big or little end?
I feel that the "all the cutters have to be the same length" notion is foolish and I know there are others that will agree
It is not for the three missing teeth lost in any random order that would cause one to raise an eye ; as for they are of equal. It is in fact, the ones in remain that raise the question.
Expert just said^^
" it won't be an issue much longer EITHER WAY". How do we follow that?
I like to just trim up the top plate or grind off the top and just leave the side when I hammer away at a cutter. Seems to let it ride over the wood with no ill effect.
BTW: this exact thread was started on AS too just in case we were unable to provide an adequate answer.
As long as there in random location should be ok but I would just keep it as a spare and get a different chain but that's just me.'Been cutting some logs/stumps into smaller pieces for burning in a neighbor's wood stove. The logs contain assorted nails, staples and other metallic tramp material and my chains seems to find them all. [I'm running 20LPX chain on the Husky 346XP.] On one chain I've had three teeth so damaged that I just ground them off. The missing teeth are in random locations on the chain, not sequential. Saw seems to cut fine anyway. Any downsides to this I should be aware of? This chain probably only has one more sharpening left in it anyway, so it won't be an issue much longer either way. What do the experts say?
LolI'd run it.
I also surprised JB weld has yet to be mentioned.
I don't have a clue of that you are writing about here. Was something deleted that was significant besides a basic edit that you speak of? I don't get the connection. He is addressing one if not both posts from one guy only and he is the azz? I was just going to welcome him to the site and give him a little more serious response. It was a fun OP, perhaps I didn't get a serious side to it until his reply back to me. Where is he being a prick. I read it on two sites and I don't see it?I just reread the first opening thread post...so times (edit sometimes) I glance and answer... not really a good way but a quick answer is something and better than none.
but when I reread after afew post I read it differently, because the op has jumped up and sharply writen reply’s.
I’ve seen this before...it’s not the best way to behave in a newly joined forum, because maybe you don’t know anyone, and other forum members and there own ways of replying.
We all have traits, and that’s good and bad.
We are a good bunch of guys and a few other genders here. Compared to some other places that other peeps frequent...
Cheers
There are also people that would use their breaker/ spinner and presets to replace with almost worn out teeth from a donor chain. They say they cut faster. If you have the time and patience.
I just run them. From this site. Not mine.
Or I justify it by the newer Chinese ones are fairly inexpensive and I can convert odd lengths that I find cheap into ones I can use by adding or subtract links. It's just another tool to do stuff. You can get away with a grinder and ball pien hammer if you're determined.
Firstly, welcome to the forum, not much offends me, sorry if I upset you. Well, you have a 346 so your either lucky of have good taste. My only advice is if you 'know' metal objects will be in the wood your cutting, change your style a little & be a bit light handed pushing the chain through the wood. Metal on metal has a unique 'feel' that resonates through the saw which you can feel if your paying attention. You can minimise damage by stopping when that unique vibration is sensed. But, pending on how much of this metal infested wood you need to cut, the chain I'd grab for the job would be the one missing teeth & near its end. Semi chisel will keep you in the game if you only lightly encounter metal & respond accordingly.Not sure why the acerbic wit my friend. You got nothing better to do on a Friday morning? As most discerned from the allowable responses to my poll, I didn't think it was an issue. I'm actually a mechanical engineer by training but my expertise lies in centrifugal pumps. I'm also humble enough to acknowledge that I don't begin know everything about anything. But I have a beloved Husky 346XP that I don't care to ruin over a $15 chain. So, I thought the poll was a lighthearted way to inquire of the group (on both sites). Having been on the internet since the early 1990's, I also knew I would get a variety of responses, some worthless, but some might have something I hadn't thought of before. You also have the option to not read the post or not respond. Why so sour? Did you take this as a personal offense?
