MattG
Chainosaurus Rex
- 3:50 PM
- Apr 30, 2017
- Cambridgeshire, England
I must admit EVEN I have got that figured now.Where are you having trouble putting the carb back on?
1. put carb on the studs, grip the throttle rod through the grommet window with pliers or hooked pick etc. and slide carb down, pushing choke rod away with other hand if ness.
2. when carb nearly at base, wiggle the fuel pipe on
3. then finally on with the choke rod
I bet I'm nearly as quick as you now wolfy!
