arthur hoffmann
OPE Member
- 11:43 AM
- Apr 11, 2017
- new orleans
On my Craftsman with a Briggs & Stratton motor which the part number is 31C707. The customer called and said that the motor would not start and then acted like a dead battery I went and looked at it I had to pull the flywheel off because of the noise I heard when I took the flywheel off half of the magnets were gone and the stator was bent in half I ordered a brand new stator and flywheel I made sure the stator was exactly the same everything is in time all the valves I tried to stator in four separate positions because of the way the screws are you can rotate it four times but I cannot get the engine to start it will turn over but it acts like it has no spark but it does and it acts like it has no fuel but it does because when I take the spark plug out there is fuel dripping off of the spark plugs so I am kind of at a loss and by the way I did run a compression test and it leak down test and we were 90 pounds 4/20 minutes somebody please help
