Adjusting the valves on a stihl fs90r 4-mix
bryanr2
11:26 AM
USA
Does anyone know what the gap thickness is for the valves? I know stihl makes a kit, but if I can figure out the thickness I can use a valve gap tool I already have.
AVB
10:26 AM
Elora, TN
.004 IN and EX.
Takes a very narrow width feeler gauge. Something on the order 7/64"
Lone Wolf
11:26 AM
Nj
You can cut a reg feeler with a scissors to make it narrow enough to fit in.
Simondo
4:26 PM
UK
I suggest you get the repair kit ..hassle free plus the cork gasket and copper washer comes with it. Here there less that £10.00 and its a good idea to scrap the gasket and washer when you do the top end IMO.
Lone Wolf
11:26 AM
Nj
The gasket is important as it holds vacuum.
Simondo
4:26 PM
UK
The gasket is important as it hold vacuum.
Think I may have given a confusing post. I did mean by "scrapping the Gasket and Washer "....put the new ones from the kit on when doing a top end ..dump the old.
Lone Wolf
11:26 AM
Nj
h
maybe somebody posts a vid of the procedure as well....
seems like witchcraftery to us "NO VALVES" guys.
Not hard to do put it at TDC and adjust valves.
