Haven't made that move into selling stuff or selling modification services. Maybe next summer when I'm (finally) retired from driving a snow plow/ dump truck. Planning to significantly upgrade machining capabilities for the channel over the next year, many might find a CNC Lathe & CAD/CAM interesting and fun. SO AFTER that's in place probably will do some stuff. You can get 90 percent there w/o a popup. Just get to .018/.020 and your going to be pleased. I really don't think a random popup concept is a good one. I measure first to see what I need as every saw is an individual. But thanks for asking! What I will do at some point is "fit" one to a cylinder assuming the crank & cases are close enough a few thousandths aren't going to go to the wrong end of the tolerance stack..
