Sty57
- 7:38 AM
- Jan 6, 2016
- Land of Cheese & Beer
Don't forget my cut......Yes. You have my paypal
Lol...you hoes are cheapDon't forget my cut......
FineYes. You have my paypal
i got your paypal also.Yes. You have my paypal
Runs great is that poplar .This is the 2nd best running $200 saw I own. I'm confident it'll get better after its ported. These are it's first cuts
That exhaust port looks awesome
I betThanks, I spent some time on it
how does the weight feel against an oem 660
My china 372s are a bit heavier than oem.
Doesn't bother me though.
i'm keeping mine they have suprised me and they are cheap and
Fun to mess with.
one of the stronger 046's I've had roughly .030 of freeport. I didn't build that saw. Came from canadadada.
Do you think perhaps these saws could run stronger if the skirt closed the port? If not, what would the reasoning be behind the Freeport not being a detractor?
No sir. I've learned over the years that I need to jump on it when I feel like doing something or it might not get done lolSo, do you feel cool kevin, makin all the rest of us feel like slackers??
I always check the skirt before machine work. I usually avoid freeporting.It's not a benefit for sure. Every saw I degree before lathe work I sit down and devise a plan considering several variables. I'm sure we all do. One of the things that I do, especially if I know I'm dropping the jug very much is check the skirt for how far I can go if need be before I run out of skirt. If my target numbers require .050 off the base but I can only go .040, then I adjust my target numbers accordingly. As to specifically avoid freeporting. Perhaps I've shown too much caution and in the future I'll pay less attention to the possibility of freeporting and shoot for numbers anyways.
I think you nailed it Kev when you said at that point in the cycle there just isn't enough going on in the cylinder for it to hurt.
An 036 isn't really that much bigger than an 026, you'd be surprised. Maybe a pound heavier.Can one buy a lighter saw for less? I'm a small guy, I'm thinking a 026 would suit me better.
I tryed to pick up a 660'one time, but someone thought it would be funny to epoxy it to the floor.
If I could get something close to a 026 I see y'all ramping over for less, I mite be interested.
I just did an oem 066 and this one about the same time. I can't remember if these are a hollow can or not. I can look tonight
Mine was hollow Kevin. I actually like the hollow muffler better. I gut the OE mufflers anymore anyhow.
Kevin, how much meat does your piston have at the bottom of the skirt at TDC? Without a gasket I've got .020 before Freeport. Handicaps me with machine work.
My muffler had baffles
