Buy Used Saws CCC Ebay Store
661c issues
Discussion in 'Chainsaws' started by Cracker Boy, Mar 15, 2019 at 6:39 PM.
  1. Cracker Boy
    Cracker Boy Fl cracker
    May 31, 2016
    4,223
    7,448
    320
    Florida
    I have a 661c I worked on for a local tree guy. I did a base delete and slight timing advance and slight muffler mod. It's runs great cold but when it's hot or you shut it off to fuel saw it won't hardly start. It takes forever to get it started again. Once it does it runs fine. It's just a bush to start cold. Any suggestions. I did the factory reset too when I did repairs on saw
    dustinwilt68 and MustangMike like this.
  2. huskyboy
    huskyboy Sorta a Husqvarna guy.
    May 30, 2016
    4,955
    18,733
    426
    Is the saw flooding when it tries to start? I had to lower the metering lever a touch on one to put more tension on it. Was flooding on restarts. I also blew out the tank vent. Whatever one of those two things fixed the one I ran.
  3. Mastermind
    Mastermind Leader Of The Clique Staff Member
    22,302
    125,481
    931
    Tennessee
    Sounds like a bad solenoid.
    Funky sawman, PA Dan, Coltont and 4 others like this.
  4. trooney
    trooney Admitted Woodaholic
    Dec 26, 2015
    1,807
    3,893
    275
    The land of pleasant living
  5. tree monkey
    tree monkey Mastermind Approved!
    Dec 14, 2015
    3,909
    31,666
    548
    wi
    let it idle for 10 seconds before shutting it off
  6. Cracker Boy
    May 31, 2016
    4,223
    7,448
    320
    Florida
    That's kinda what I'm leaning toward myself randy
    PA Dan and BuckthornBonnie like this.
  7. Cracker Boy
    May 31, 2016
    4,223
    7,448
    320
    Florida
    The way he described it to me is what it sounds like honestly that it is trying to flood. Says it takes 2 guys and smokes and skips
    PA Dan likes this.
  8. Mastermind
    22,302
    125,481
    931
    Tennessee
    Flooding is normally a solenoid issue. But......it's still just a carb, so it can be a needle & seat, or any other carb related issue.
    smokey7, PA Dan, ferris and 4 others like this.
  9. Cracker Boy
    May 31, 2016
    4,223
    7,448
    320
    Florida
    I'm gonna pick it up and run it some and see what she does in a day or so.
    PA Dan likes this.
  10. Coltont
    Coltont ONE OF THE GREATEST!
    Jan 2, 2016
    1,084
    5,490
    407
    Pennsylvania
    Smash it and give him a 660?
    smokey7, Dub11, blacksmith and 4 others like this.
  11. drf256
    drf256 Dr. Richard Cranium (“RC” to Muh pals)
    6,687
    42,186
    543
    What is his starting technique on a warm saw?
  12. TreeLife
    TreeLife I like saws
    Jan 24, 2017
    2,411
    9,405
    330
    Berkshire County, Massachusetts
    That's a good question and something worth discussing with the electronic saws, is the old rule of "warm saw, high idle start" still applicable?
    smokey7 likes this.
  13. drf256
    6,687
    42,186
    543
    I don’t know a damn thing about MT saws. I do know that I’ve read that people try to start the “old way” and get tons of problems. The correct procedure on a warm MT saw is to just pull the starter and do nothing else, otherwise the computer senses that you are in choke mode.
    Again, going by what I’ve read.
    PA Dan, Finnrpm, huskihl and 2 others like this.
  14. Redbull661
    Redbull661 661 hoarder (BlueBallz)
    961
    10,089
    463
    wisconsin
    I've had this happen several times early on owning 661s. Here is what works for me.
    let it idle 10 seconds before shutting off. That should keep it from happening again.
    If it happens again. Pull the air filter cover, air filter, spit back cap. Pull Trigger and gently blow down carb/ into intake boot. Now start the saw. Replace spit back cap, air filter, and air filter cover.
    Dub11, PA Dan, huskihl and 3 others like this.
  15. redlight066
    redlight066 Super OPE Member
    Apr 1, 2018
    334
    1,815
    198
    Taylors SC
    The soleniod spring is getting weak and won't get any better. Along with the symptoms you mentioned, It will also idle a few hundred rpm's lower than normal like its struggling to maintain a steady idle if its bad. I know this seems silly but a fresh fuel filter and spark plug twice a year makes a difference on the M-Tronic saws. That soleniod needs a completely unrestricted fuel supply to make the constant tuning adjustments accurately. Be careful installing the new soleniod, the O-ring needs to seat correctly, it's tiny. Do the filter and plug when you do the swap. Reset when you finish then run it like you stole it.
    Dub11, Cracker Boy and Gary Courtney like this.
  16. Cracker Boy
    May 31, 2016
    4,223
    7,448
    320
    Florida
    It's a local tree guys saw. They are so rough on stuff it's unreal. I changed the filter when I did the piston change and the mods about 6 months ago. I have been leaning toward fuel solenoid myself the saw has quit a bit of hours
    ferris likes this.
  17. Mastermind
    22,302
    125,481
    931
    Tennessee
    If it has a white solenoid the reset process is different. But I don't think it's that new is it?
  18. Cracker Boy
    May 31, 2016
    4,223
    7,448
    320
    Florida
    No its older I belive can you tell me reset process for each please
  19. Mastermind
    22,302
    125,481
    931
    Tennessee
    Older type. 90 seconds on choke, brake off. Shut off without touching trigger. Restart.
    Newer type. 30 seconds on choke, then pull the trigger WFO, and hold wide open till it stops surging and speeds up.
  20. Woodpecker
    Woodpecker Wooden Member
    725
    3,107
    264
    Saw this vid somewhere else on the reset process for the different versions. Seems relevant:
    Redbull661 and angelo c like this.
Loading...
Share This Page
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
