I just received my printed block and am here to report it solved my fast idle issue. Thank you to everyone who made this solution work out, I greatly appreciate it.
Ive been scouring the internet to try and figure out my high idle issue and came across this awesome sight. I joined the group and came across this thread. I tried making my own version of the diagram that was posted but it didn't fit right. Any chance you have any of these left? Thanks,Rich
I knew I should have patented this and sold it. My error. I think the supplier (jmester in MD) should have some left. This also fits an 066 and a 650 should they be having the same problem. The carbs need a fast idle to start the engine cold. They seem to start OK when warm but not cold without the fast idle.
My saw is actually an old red eye 066. I put a new tank on because my old one was leaking and had a busted ear for a mount. This new handle hasn't worked right since i put it on. Definitely need the fast idle for cold start!
The old control lever is a completely different design. A better one at that. I tried to make it work . But it won't fit.It was one of the old red ones with a big circle on the shaft right where the new ones need a shim.
