traffic903
- 9:08 PM
- Aug 28, 2017
- Australia
Since assembling my 660 project I, like many others, have had a problem with the fast idle not working as it should. Instead of "locking" in position when moving the master control from choke to fast idle, it would simply slide straight into the normal idle position. I found this very frustrating when starting.
So after trying many different things to solve this problem, and failing miserably, I started scouring the web for an answer. It took forever to find something definite about this, but I did eventually come across a post on Arb....tsite by Wood Doctor. FULL CREDIT FOR THIS SOLUTION GOES TO WOOD DOCTOR. I am just recycling his information and images because due to the photobucket fiasco, they are no longer available (unless you know how to get around the problem ).
I am not sure whether I can post a link to that site or not so I will just post a VERY short summary of his fix.
First you need to make this "shim."
Then you fit this shim in this location........
The shim pushes the left side of the master switch back toward the trigger, and in doing so makes the whole mechanism work correctly. I just made mine up out of some aluminium flat bar. Super simple, works perfectly.
Once again, not my fix, thanks go to Wood Doctor. I hope he doesn't mind me using his images.
Cheers.
Cheers.
