Although I hate to see this, it does show up the inconsistency in the production of the product.
Have you seen gravedigger 660 page 3. He then talks about an upgrade crank from hlsupply
Cheers for posting.
And yours shows the same bit/chip missing by the side of the conrod, albeit the other side.
Edit: not really sure about the bit missing, it looks like it could be a lubricantion point as other FT cranks seem to have them, although gravedigger's upgraded crank does not have this/these bits
Btw have a good read of his post/build thread?
Cheers and good luck
I've been fishing last week and don't have it back together. Need to order piston as it broke the skirt. Debating on replacing top end also.
The crank is definitely a lot better quality.
What crank did you get? Were your crank bearings okay?
I got from HL Supply in my garage, awaiting assembly. BTW, all of the bags in my kit are marked Cross Performance. I thought that was odd, since I haven't seen that mentioned
Is it possible that the rod bearing failures are from excess heat created by the rod rubbing on the side of the crank journal, and overheating the rod bearing? In other words, the crank/rod assembly being off center in the crank case, relative to the centerline of the cylinder. Its a long shot, and I am not sure how to accurately check for this condition other than visually on the rod journal after failure and teardown. Its odd that the rod bearings fail, but we don't see much in main bearing failures.
This is my first post here, and I'm trying to learn as much as I can about these Chi-Com MS660s. I have a box full of parts I got from HL Supply in my garage, awaiting assembly. BTW, all of the bags in my kit are marked Cross Performance. I thought that was odd, since I haven't seen that mentioned in any threads on here, or the countless Youtube videos I have watched on the subject.
I hope to learn much from the wealth of knowledge on this forum, and maybe someday be able to share some as well.
