stinkbait
I just finished up a ms660 build where I used an aftermarket 54mm cylinder and a 288xp piston. I cut the squish and base to bring the exhaust down to 98° and ended up at .022" squish. I cut enough from the chamber to where I had to ad a shim to the plug to index it so that it didnt hang below the squish band. I used job weld on the intake. Ended up with ex- 98 trans- 123 and in-83. What's puzzling to me is I'm only getting 155 psi after a couple heat cycles. Do y'all think the low compression is due to crappy aftermarket ring? I'm used to these numbers producing serious compression. Here are some pics of the cylinder roughed in. Didnt get any after it was done.
