shadco
Ban Hammer Custodian
- 9:06 AM
- Dec 10, 2018
- City of Oaks, NC
You don't want to remove those unless there is an absolute need...like porting.
There's a rubber o-ring that goes around the perimeter of that cap. Sometimes they break, and you can't buy a new o-ring without purchasing a new cylinder. Normally I don't even take the covers off when I port them, unless it's a model with a restrictor in themWouldn't wanna fry the sausage.
That’s all kinds of *f-worded up right there.Sometimes they break, and you can't buy a new o-ring without purchasing a new cylinder.
If i do remove them, I feel a lot better installing them with a little something extra just for insuranceI had a bad screw and a broken seal on a beater 550 of mine. I Yamabonded it and slotted the screw. It seemed to hold up pretty good.
Couldnt hurt right?If i do remove them, I feel a lot better installing them with a little something extra just for insurance
Well, that depends. I saw a pic on AS where the guy did a base gasket delete and squirted a bead of silicone onto the base right from from the tube. Apparently it didn't run very well, and he took pictures on disassembly. There was a quarter inch bead of goo all the way around the inside of the cylinder LOL. I just smear a little tiny bit on my finger and rub it around. Just so it's wet.Couldnt hurt right?
Lol! Ok no silicone! Gotcha!Well, that depends. I saw a pic on AS where the guy did a base gasket delete and squirted a bead of silicone onto the base right from from the tube. Apparently it didn't run very well, and he took pictures on disassembly. There was a quarter inch bead of goo all the way around the inside of the cylinder LOL. I just smear a little tiny bit on my finger and rub it around. Just so it's wet.
That was my comment over there, word for word. LolBet it didn't leak though. Lmao
