394XP - Work Saw Rebuild
Duke Thieroff
Fill your hands you SOB!
8:08 AM
Beaver County, PA
In my search for a mechanically sound crank case half I stumbled across this one on eBay. As it turns out, this thing is so nice it meets PSP standards. No cracks, no corrosion and barely any noticeable chips in the finish. Couldn’t be happier with this for my saw.
After conversing via email I found out the seller is a member here with a solid reputation as a good dude. Check him out if you need some parts, you won’t be disappointed. Thanks again @Duke Thieroff
Hey!
Thanks for the shout out bud!
Awesome job on the saw, you offered up a ton of helpful tips. This reminds me that I need to get back into the shop to put something together instead of always taking things apart.
XP_Slinger
They’re Just Saws
8:08 AM
Central NY
Thanks for tossing that out there. Both of my 394s have no provisions for mounting the guard.
My brother has an in betweener 394. The bosses were cast into the case but weren’t drilled and tapped. I believe his is a 96’ model but @RIDE-RED 350r would have to confirm.
XP_Slinger
They’re Just Saws
8:08 AM
Central NY
Hey!
Anytime Duke! And thanks for the compliment bud, much appreciated.:beer-toast1:
qurotro
Cookie Cutter
7:08 AM
Ar
Good thread man. But i wanna know how's your way to file to key to get advanced timing? My stupid hands just don't like doing it.
Onan18
OPE Sponsor
8:08 AM
Georgia
I can personally attest to how much time it takes to do a thread like this. Not just the time to post but also having to stop and take pictures along the way, lay things out where they can be seen, lighting, glare, etc... It makes a two hour job into a 4 - 6 hour job or more. Kudos Josh for taking the time to do such a well documented rebuild.
grizz55chev
5:08 AM
Calif
Ignition and flywheel assembly.
First install the air injection duct.
Next install flywheel then the coil with 2 fasteners and set the gap to .012. Route kill wire and spark plug wire as shown.
Shaved the key for a timing advance.
Coil took some damage when this saw got wheel chocked. OCD is telling me to replace it, but since the saw ran fine with it I’m going to run it til it fails. If this were a saw for someone else I would recommend replacement.
Last thing was some shrink wrap on the plug lead to protect some areas that are chaffing. Again, I wouldn’t bandaid this if it were for anyone other than myself.
Put those damaged legs of your coil in a vice and squash them back flat, won’t hurt a thing!
XP_Slinger
They’re Just Saws
8:08 AM
Central NY
You’re gonna laugh. Since I consider myself a hack, I used a hacksaw...lol! Clamped the key in my vice and managed to cut a blade width off which came out to be about .035. A little more than my usuall but you never know anything til you give it a try. Dressed it up after the cut with a small file, didn’t take much.
XP_Slinger
They’re Just Saws
8:08 AM
Central NY
Thanks Joe. Means a lot coming from you bud:beer-toast1:
8:08 AM
Forgot to mention previously. After the carb is installed check to make sure the throttle arm has full rage of motion from the idle stop to the WOT stop. If it’s not resting on the idle stop check the cable on the trigger end, the housing is likely not seated properly in its recess.
Resting on idle stop.
Full travel to WOT stop (carb housing). Good to go.
I've seen a couple 394/5's not open the throttle all the way. The carburetor bolts have enough slack in them to where you can rotate the carburetor clockwise against the bolts and retighten them to take care of this slack. Might help somebody down the road
srcarr52
8:08 AM
Iowa City
I just make a shim out of aluminum for the throttle cable end. Just drill a hole, slit it and crimp it on the cable.
qurotro
Cookie Cutter
7:08 AM
Ar
That takes even more skill than using a small file lol... I might try use dremel tools next time.
XP_Slinger
They’re Just Saws
8:08 AM
Central NY
Sometimes the throttle linkage pivot piece in the handle wears out too letting it get too much slop.
Great info guys! This is what I enjoy most about putting up a thread like this, lots a guys start sharing experience.
Cobby08
I’m a face down ass up guy
8:08 AM
Central New Yawk...
Got ya beat... on a lazy day I've used a pneumatic cutoff tool. haha... No shame in my game.
