ELECT6845
- 4:01 PM
- Dec 28, 2015
- INDIANA
2016 model saw with 130 on compression. I pressure and vac tested it, no leaks. Not a bad looking saw has typical scratches from use.
THE BAD
Crank bearing is noisy on the PTO side I do believe. Missing flywheel fin which appears to have put a hairline crank in the thin case strip about the flywheel. I believe jb weld was used to help strengthen it.
300.00 plus shipping.
THE BAD
