SOLD 372xpw cylinder kit
mpearson
New OPE Member
5:40 AM
Colorado
Worth it! Converted my xtorq to an xpw. Much more torque.
Steve,
I'm considering doing the xp x-torq to xpw conversion, and I'm curious if you kept the x-torq carb or switched it out? I'm hoping to keep the x-torq carb, pull the dividers, and use the 390 intake boot. Thoughts?
Steve
Excellence!
6:40 AM
Steve,
I used a zama el2. You wont gain anything using an xtorq carb unless its ported. The xpw cylinder is choked out compaired to the xp. It will work but you wont gain anythin above what the cylinder can flow.
mpearson
New OPE Member
5:40 AM
Colorado
Thanks Steve,
I think I'll probably roll with the xtorq carb as I've already got all the parts to make it work, and it sounds like I won't be losing any performance by keeping the larger carb.
