Gord
- 12:05 AM
- Dec 14, 2018
- British Columbia
Wonder if anyone has run across this before and is there a way to fix it on my 372 build- using a K model crank they have a hole where the clutch bearing looks like it should be for greasing the bearing but instead it leads back into the crankcase causing an air leak, change cranks or is there a way to plug it permanently, all together and it showed up on a leak pressure test,???
