Buy Used Saws CCC Ebay Store
365/372 Chinese chainsaws
Discussion in 'Chainsaws' started by Czed, Jan 31, 2017.
  1. smokey7
    smokey7 Pinnacle OPE Member
    Feb 3, 2016
    1,161
    2,625
    275
    Detroit
    I simply love those echo style vents. I buy them 10 at a time and use them on everything. I like them so much better then just about every other style ive messed with. They are cheap and so simple to retrofit to everything even if you gotta glue them in like @Leafy did. Lol nice work BTW.
    Czed likes this.
  2. Czed
    Czed Mastermind Approved!
    13,828
    73,088
    540
    [​IMG] huztl introduced these 50mm 372s
    Today 251.00 shipped
    If anyone buys one
    Tell us how it is.
    redpete79 likes this.
  3. Leafy
    Leafy Well-Known OPE Member
    May 3, 2018
    234
    437
    98
    NH
    Thats cheaper than the build kit isn't it?
    I cut up an oak with mine, runs good but doesn't really have enough more power than the China 5200 to be worth the weight. I'll still use the 372 in hardwood over like 14" vs the 52cc but that's really it. I think it needs more carb to cut faster. That's even running square file on the 372 vs round and 8 pin vs 7.
    Czed likes this.
  4. Czed
    13,828
    73,088
    540
    Got one of the hyway bigbore 372 popup kits
    Looks good.
    Nicely finished cylinder
    The popup is small i don't expect the 170s
    The 268/272 popups have.
    They have 50mm popups on their website
    P.M.P., redpete79 and smokey7 like this.
  5. Nutball
    Nutball Super OPE Member
    Oct 31, 2018
    354
    909
    163
    Mt. Juliet, TN
    A coworker just got a "Holtzfforma" 365 today. Yes, the vibration especially at idle is significant. I've found that a ms250 engine made by the same people (Farmertech) has a heavier piston than crank counter weight, so that could be it. He put a 24" oregon bar on it, and I tuned the carb. Its been a few years since I ran a chinese 365, so I can't tell how much relative power it had, but it does well. I think 24" is pushing it oiler and power wise. It came missing a bolt for the cylinder to handle spring, so I found an oversized one to install. After all these years they still have too much play in the clutch drum, so it has the ability to disconnect from the oiler. I've never let one go to find out if it would eventually tear up the oiler arm, I've always made and added a nylon washer. It sure spills gas easily out the tank vent.
    This is me by the way back when I used to mess around with these.
    Fun fact: in the video I gathered these RPM characteristcs:
    First 365: 7000 max power, max torque around 6250 (aggressive new 33RS chain)
    Second 365: 6800-8400, max power/cut speed ~8500, peak 9250 still cutting
    Czed likes this.
  6. Stackowood
    Stackowood Super OPE Member
    Dec 17, 2016
    384
    959
    173
    West coast
    I just finished the HLS 365/372 kit that was on my shelf for a year. Had to use a few OEM parts- oiler grommets, fuel filter, air filter cover clips, little stuff. The clutch drum was out of round, so a Oregon drum is on order. Compression is 150 with Caber rings. Should I go ahead and modify the tank vent, or have some been ok?
    Czed likes this.
  7. Nutball
    Oct 31, 2018
    354
    909
    163
    Mt. Juliet, TN
    I didn't investigate my latest one since it's not my problem, but it lost a lot of gas in my car on the way home from testing at a log dump site just by laying on the clutch side. My 2188 only looses gas if set on the starter side. So, yea, probably should check and modify it. And the clutch on this one was out of round to (a wobble off axis, not really out of round in shape, but crooked on the shaft).
    I cut some huge 40-60" chunks of silver maple with it recently. 24" bar. It took a really long time, but kept working. I let it do the work and kept the rpms high around max power.
    Be nice to it, grease all moving parts: oiler worm gear, clutch bearing, chain tensioner. I've had an oil pump seize up and strip a gear on the first run of my first chinese 365. I still cut a whole 16" oak into firewood with it like that
    Czed likes this.
  8. Czed
    13,828
    73,088
    540
    I only have one am tank with that style
    Vent.
    No problems so far.
    A few guy's had issue's and had to mod them.
  9. Stackowood
    Dec 17, 2016
    384
    959
    173
    West coast
    Thanks, looking forward to getting some hours on it. The crankcase was in a separate box labeled "made in Italy" and it seems to be very good quality with nice machine work.
    Czed likes this.
  10. huskyboy
    huskyboy Sorta a Husqvarna guy.
    May 30, 2016
    4,974
    18,928
    426
    That’s a common problem on the vents on those saws when they get older. I think the ethanol warps the tank as a new vent didnt fix the problem for me. Either fit the older style vent with the white puck or do as I did and use threebond, dirko or some type of gas resistant sealant liberally on the od of the part that goes in the tank (clean the surfaces with a q tip and carb clean first).Works well and the vent can be removed in the future with a drywall screw if needed.
    Czed likes this.
  11. afleetcommand
    afleetcommand Pinnacle OPE Member
    Jan 25, 2017
    506
    1,984
    203
    CNY
    I roasted the Hyway top end on one of mine, busted it down and cleaned it up. Stuck that saw back together and it runs as strong as ever, I did notice even before I stuck that saw there was a lot of piston rattle....its louder now..LOL! BUT cuts like crazy. The Huztl kit saw and their "G365" power head I have both run well, start well and seem to be solid builds. None of mine are pretty anymore as they ride around either on the tractor or in the back of the pickup truck..and get used. Not looked at.
    thesawincanada and Czed like this.
  12. Czed
    13,828
    73,088
    540
    I put a hyway big bore popup kit on today on a older china
    Saw.
    Looks good didn't touch anything no sharp port edges.
    Comp feels good have to check it.
    I have to change crank seals
    The pto side is leaking.
    20181208_160241.jpg 20181208_145916.jpg 20181208_170423.jpg 20181208_145924.jpg 20181208_150040.jpg this style had the vent hose instead of the puck/disc so i use echo vents.
    Haven't had any issue's.
    Termitebuffet, redpete79 and huskyboy like this.
  13. Czed
    13,828
    73,088
    540
    How's the 268 popup piston doing you made?
    I like them some don't.
    Those and the 272 popups I've been running are still doing good.
    Termitebuffet likes this.
  14. Czed
    13,828
    73,088
    540
    The hyway runs good tuned it in poplar
    Put a ft cylinder on a xt with a 268 popup
    It definitely has less vibrations
    Than the china saw.
  15. Terry Syd
    Terry Syd Pinnacle OPE Member
    1,135
    3,984
    275
    Comboyne, NSW Australia
    It looks like the BB jug still has the 'shrouding' of the lower transfers. Did you do any porting on the new BB Jug?
    I like the idea of a pop-up piston for these.
  16. Czed
    13,828
    73,088
    540
    Didn't touch it
    Most will just bolt them on and go
    I wanted to try it out of the box.
    Runs strong seems like it'll be a good
    Grunt saw.
    Not broke in though.
    Those hyway popup pistons were on sale 20.00 on their site.
    Hl doesn't have them at least not yet
    I'm going to try a 50mm 372 popup next.
    And a 268 popup for my 268xp.
  17. huskyboy
    May 30, 2016
    4,974
    18,928
    426
    Those transfers looked a lot more open to me than the xpw or 365 cylinders I was in.
  18. Czed
    13,828
    73,088
    540
    Runs good has good torque on it's third tank now. 20181210_120929.jpg a lot more vibrations than my 266
    A lot more power too.
    Termitebuffet and redpete79 like this.
  19. Stackowood
    Dec 17, 2016
    384
    959
    173
    West coast
    Has anyone had a Cross/ Huztl 365 crank that is slightly bent? When I pull the engine over with a slack chain, the chain goes slack/tight. Barely noticeable.
  20. huskyboy
    May 30, 2016
    4,974
    18,928
    426
    Pretty much every saw does that a little. The rim wear groove usually does that I think. But I did get a 372 tecomec crank that was bent so badly you could see the end play looking at the clutch moving up and down! The chain went from tight to very loose.
    Stackowood likes this.
Loading...
Share This Page
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
