Eagle1899
- 11:05 PM
- Oct 31, 2017
- Central Minnesota
Hey everybody! New guy here.
I built one of these with the BB top end I ported myself and ditched the base gasket on. So far I've been very impressed with it like most of us.
I've been reading over this thread and decided to try some of the other mods. I did a muffler mod to the open port style going from the 1/2" outlet to a 3/4". Sounds great!!! Looks Tits!!!
I also had a spare carb from when I first put this together. It is a Chinese twin jet. I ordered up pin drills, popped out the high jet and got to work. I went with .35 / .40 / .55 mm Swapped carbs and fired it up. Top end and mid sounds stronger!!! I have no response on the idle screw or the low needle. No spitting back at idle and it will idle forever but off idle dip-in is a little sluggish off idle.
I am not sure if I need to slot the butterfly at little or shim my needle spring.... any help would be great!
And on an interesting note..... I contacted HL Supply about the aftermarket 372 carb they carry. I was told it is a twin jet. I will need to order one to be sure...
