Any Chinese chainsaw and chinese parts discussion
Leafy
2:43 PM
NH
I still had no spark after that. I put in an old ngk out of a saw the runs and it has spark. But I think I've flooded the *f-word out of it, it was blowing fuel out the decomp. It's also all black instead of blue, I should have rinsed the tank out
2:43 PM
Decomp on choke off throttle wfo pull the piss out of it lol
Leafy
2:43 PM
NH
I'm just letting it sit in the sun. My as hot as it gets without a lathe China 5200 started on the 5th pull and I did the light limbing I wanted to do that with that. I'm going to go try again now.
Leafy
2:43 PM
NH
Is it pulling in bar oil?
2:43 PM
Did you do a pressure/vac test
Leafy
2:43 PM
NH
I had it running for a good minute and I was adjusting the L and it died. There was a lot of black liquid in the crank case. It was runny though. I did pressurize the crank case and it held air but I also already installed the oil and gas caps.
I poured out what was in the crank case and I'm just going to try again tomorrow. Would really suck to have to split the cases.
I did pull the clutch off and it was dry around the seal so it's not sucking in from there.
2:43 PM
You'll know if it's pulling bar oil lol
My first china 372 the gasket let go
And i could make vertical cuts
But horizontal cuts i couldn't see the saw from the smoke lol
Leafy
2:43 PM
NH
Lol I just have flooded it really bad I guess.
So now it doesn't spark at all, even running the flywheel with a drill. Time to try huztl customer service again.
2:43 PM
Good luck
It's like talking to a wall
Anymore
They used to be good.
Leafy
2:43 PM
NH
Is there a place to buy a coil that doesnt suck? If huztl sends me one it can be a backup. Is NWP really worth the money over un branded china? And/or is OEM from a place like jacks worth $20 over NWP?
2:43 PM
I've never had a bad china coil
Been lucky i guess.
Check or post coil wanted in the parts thread for oem.
Hl supply has them 19.95
And they have been good about
Standing behind their products.
Poleman
12:43 PM
Rapid City,S.D.
I like the preventative and in depth “cat scan”!!!!!
That’s something I want to try also.... use the x torque carb!!
2:43 PM
What was your idea
Tell us what works lol
Cat's named bastard he was found in the mountains
He attacks about once an hour
Bored i guess
Poleman
12:43 PM
Rapid City,S.D.
I just wanted to try the WJ carb to see if there would be any benifit with it. Always trying to find better. I would be sure to post results, good, bad or!!!
I gotta helper like yours....doesn't attack....just wants a snack.
2:43 PM
Trade?
2:43 PM
Update had my first failure with the 372 coils
It wouldn't rev to wfo
So i swapped it for a huztl
That one took a *s-word too
It would just idle wouldn't rev
