TheJonsberg
- 2:35 AM
- Feb 9, 2018
- Løkken Verk, Norway
that can very well be the difference between W2 and 3, or there are a slighly timing difference.
On them 242 Mahles we had this non W, then W2, and the 98 jug was W3 I think, small differences but they was there when I really started to fine study them, it was the transfer ports.
This is what I like.. TOR ! Thank you all the best to you!254, year 87, OEM jug, thin ring piston, 0,4mm gasket, 020" squish, pretty much close to stock with a 0,5mm gasket, but those jugs had a very little compression chamber......
I like them just as much as I like 262's....maybe a tad more also.
Except those 4, there is two other Mahle out there, and one KS with decomp:
The one who gives this insane compression is stamped the same as the one left bottom, 86.
