Ronie
I put this up for sale over on AS as a project saw and quickly took it down when I noticed some epoxy on it. So I decided I'd go through it myself. the epoxy I noticed turned out to be nothing but after cleaning it up I found some more and even worse when I pulled the bar plate off I saw that one of the studs had been replaced with a screw in stud and a heli coil. It's in there tight and not leaking oil but I just don't like it so at some point I'll be changeing out that side of the crankcase. I may pull the heli coil out and put a threaded insert in there or drill it out and press a sleeve in the hole so I can use the oem stud. For now it's going to stay the way it is. You can see in the pic how the coil s sticking out and I'm going to cut that portion of the coil off. Below the stud where the bumper goes there is a little epoxy that's been painted over.
