SOLD 262xp
Redfin
Meh...
7:14 PM
Central Pa
This one is pretty friggin nice. I have put a few parts on it and gave it a bit of a shower to find any issues.
Almost new clutch cover, new chain tensioner. Saw is blowing 140psi @ 2100'. Piston looks very nice through the blow hole.
It has a 120 carb, idles, runs and oils well. IMG_2935.JPGIMG_2936.JPGIMG_2937.JPGIMG_2919.JPGIMG_2932.JPG
Redfin
Meh...
7:14 PM
Central Pa
These are the discrepencies I have found. Handle has a bit of rash at the base. Air deflector was cracked, I welded it together to keep it off the flywheel. Intake case gromet has a corner broken. And the po wrote thier name on the handle which I removed with some acetone. Its slightly visible, it may remove with a tad more work.IMG_2925.JPGIMG_2930.JPGIMG_2933.JPGIMG_2922.JPGIMG_2923.JPG
Redfin
Meh...
7:14 PM
Central Pa
I will ship this for $425 in the lower 48. Other locales we can discuss.
If you have any questions pm me for my number and we can talk. If you recieve this and feel its not as I described I will buy it back.
