Redbull661
661 hoarder (BlueBallz)
- 11:17 AM
- Dec 31, 2015
- wisconsin
Have had some questions about 261 mtronic solenoid, pickup body, and coil/control module. So I did some research...
- 261 362 coil/cm - from what I can tell there hasn't been any serious issues with the coil/Control module. So unlike the 661 the mtronic kit which includes a new control module, white solenoid and orange pickup body. The 261 and 362 mtronic kits (1140 007 1802) only include a white solenoid and orange pickup body.
- 241 - was discontinued before white solenoid orange pick up body upgrade. 241 schematics show new orange pickup body as standard. But do not show new white solenoid as the current solenoid. I don't see why the new white solenoid wouldn't work but best to call stihlUSA to make sure. ie. if you were having issues and bought a mtronic kit...which no mtronic kit is listed for 241.
- 1140 007 1802 mtronic kit for 261 & 362 (pick up body and white solenoid) = shows $51 dealer and $51 retail. Good luck getting it for $51. Don't know why they list it like that.
- old black solenoid (delicate and full of issues) - pn 0000 120 5110
- new white solenoid (across the board fix for all mtronic models) pn 0000 120 5104 - retails 88.75 dlr ~60ish
- new orange pickup body/fuel filter is lower micron rating pn 0000 350 3518 - $3.50 I checked 026 241 261 036 362 044 440 441 461 462 064 660 661 880 ..so it seems to be the across the board new fuel filter for most models.
- Reset OR Calibration is determined by the coil/cm NOT the solenoid. Maybe someone could chime in with, which coils on 241 261 362 441 are ver1 ver2 mtronic (reset) and which are ver3 mtronic (calibration). See below for reset procedure and calibration procedure.
- 661 - take rewind cover off, if on the coil = 4700c, 4700d, 4700e, 4701A coil/CM = reset (warm saw, then 90 sec choke, shut off, 5 test cuts). "reset" resets the carb to settings at the factory. Tunes itself in 5 cuts. If on coil it says 4702A = version 3 = calibration (warm saw up, choke for 30-60 sec, pull & hold throttle WOT, runs approx 10k rpm for approx 15-20 sec, then on it's own bumps up to max rpm ~13kish for 5-10 sec, then on it's own backs down to ~10krpm, at which point you finally let go of trigger)
- 661 mtronic kit (orange pickup body, white solenoid, ver3 4702 coil/cm) = 1144 007 1801 = shows $51 dealer and $51 retail. Good luck getting it for $51.
- 661 coil to solenoid compatibility - Stihl USA tells me you can only use 4702A coil/CM with white solenoid. And just buy the kit. Before the kit came out and before there was a ver3 coil/cm. The white solenoid was available and I did for a short time run the 4701A coil with a white solenoid. So fwiw I am not sure that is entirely true. But may just be easier to get the kit and be done with it.
- 462 - comes with white solenoid, orange pick up body and ver 3 mtronic coil/CM. So calibration only. No kits.
