254XP Rebuild
XP_Slinger
They’re Just Saws
6:26 AM
Central NY
Seems like its time for another 2-series rebuild. Here’s where I’m starting from, saved this mostly complete 254 from the junk shelf at my dealer. I’m going to try to give good details like @Onan18 has been in his series of repair threads. I’m no Joe but here we go;
08B60807-797E-4682-A825-063F3B87D80E.jpeg DCE35FEB-9D6D-40AE-B35D-90D5125A6E1A.jpeg
XP_Slinger
They’re Just Saws
6:26 AM
Central NY
1 screw releases the air filter, now it’s time to pull the carb...after a little cleaning. Remove the throttle linkage, 2 filter holder screws, 2 carb mount screws then disconnect the fuel line and it comes right out.
72605637-755B-47B3-B2C0-C9CEA2CBC734.jpeg EA4B5714-8627-4651-B16F-EC2D16E0E281.jpeg FAC54C22-F829-4AB4-8583-713D897D8F19.jpeg 04AE20C9-12B6-450C-A49E-AF5E8648DEEF.jpeg
XP_Slinger
They’re Just Saws
6:26 AM
Central NY
This coil screw, like many others was packed full of saw dust and bar oil. I pick them clean during disassembly so I don’t round them out. This dental pick does an excellent job but any small pick or screwdriver will do.
Remove 2 screws and the ignition coil lifts out.
51189B55-29D6-484B-8603-93D0E4684233.jpeg B7092B5B-8ECE-4A9B-8FE7-FFC62ABD6DFF.jpeg
XP_Slinger
They’re Just Saws
6:26 AM
Central NY
Next I removed the clutch using a piston stop. I usually just hold the flywheel and blip the clutch with an impact to remove it but this saw was missing the flywheel. Clutch nut is 15mm reverse thread.
E474F7E6-3640-4D47-ACAE-FEB41275433B.jpeg 75E35EA7-3AAE-4A04-90A3-C769288F0A3A.jpeg 42928579-ED1D-48CD-9F5F-1D6E2C420A37.jpeg
XP_Slinger
They’re Just Saws
6:26 AM
Central NY
Now that the clutch is off, there arent any more bolts that are tough to break loose so I remove the handle. 2 screws on the side, 2 more on the bottom. The longer screws go on the side With the black spacer.
I also took the air injection plastic off at some point. Pretty simple, just 2 screws and it lifts out.
XP_Slinger
They’re Just Saws
6:26 AM
Central NY
Now it’s time to separate the fuel tank from the crank case. There are only 4 mount screws. 2 are toward the handle up top and the other 2 are near the front of the crank case near the bottom. The fuel line just pulls through the grommet and stays with the tank.
E0C52CBC-5A5C-40B5-8ACE-1AB026C08986.jpeg 4882EAB9-8BC4-4210-B46D-4801BBAA543D.jpeg 6F992749-3C35-4F4C-AF30-3EE3548625A4.jpeg AC64E268-A138-4965-89EC-D804CAC5774D.jpeg 48B25B35-9181-4CC1-8648-AE93C66F306E.jpeg
XP_Slinger
They’re Just Saws
6:26 AM
Central NY
Next up for removal is the flywheel side seal carrier. 3 fasteners and it comes off to reveal the crank bearing. Note the large oring on the seal carrier. It must be replaced to ensure an air tight seal when reassembling.
FA84B25B-9F07-4DDA-BBFF-F4ED41547F20.jpeg 4482306C-0055-4ED8-9110-2BC82BDE31CE.jpeg 68F8A0E4-AD5E-4B18-8B1B-ED62AB53210C.jpeg
XP_Slinger
They’re Just Saws
6:26 AM
Central NY
Now to remove the oil pump. 3 fasteners secure the pump body to the crank case. Once removed it will lift right out right? Not so much, I gently pryed on this thing for 20 minutes before making a discovery. These 2 holes are threaded for 5mm bolts. Using cylinder bolts, thread them in until they bottom out on the case, then slowly tighten them and the pump assembly rises out of the grim and into your hand.
