SHOVELHEAD
I responded to your PM
& then I seen this thread.
Have you found your #s your looking for?
On it! Did find a couple used OEM 359 cyls on AS real cheap but I think I want the whole 357 new from spike60.My advice( It's worth what you paid for it) stop messing around with that junk and get a good PC .
Shep
Is it going to some with a new piston bearing?
I wouldn’t risk all your hard work by running that cheap am ring that looked damaged in the picture.Initial numbers with .018” gasket after taking .028” off base.
In : 82
Exh : 104
Xfer : 120
Squish .023”
Compression 150psi. Little disappointed in that. Cheap ring methinks.
What are you guys' thoughts about those numbers? Got my 357 coming from @Spike60, but might as well see if this one will run worth a hoot. I think the ring isn't worn in yet, that damage looks a lot worse in the huge pic than it is. I don't think the guy who built it ran it more than to test it, as did I. We shall see.
Muffler is also AM with 3/8" dia outlet. It needs opened up big time, I'll post up on that later.
Another thing I need to do is pull the clutch and oil pump. The crank has some resistance and I can't tell what it is. Not wanting to split cases but want to get a good feel for bearings.
Thanks!
