- 3:39 PM
- Jan 24, 2018
- Extreme Southeast CA
Howdy, I’m the new guy. Met Marshy on the book face and he pushed me to post up. Been talking to @Chainsaw Jim a bit on YouTube too. Looks like he might be the closest builder to me here in SoCal.
Been away from sawing for a few years, bug bit again. Got a used 2159 that was rebuilt with an as-yet unidentified AM P&C and it can’t hardly pull the 3/8” forester chain on it. Maybe not broken in yet? Maybe vac leak? Looks good in the exh port. Still has plastic intake clamp, need to remedy that and rig up a setup to pressure and vac test. Have a 49SP I’m pretty sure has a crank seal leak I need to do next...
Pretty sure the 59 hasn’t had seals put in it so considering a (used?) stuffer crank and new top end on the forum’s recommendation. (Can that be done without splitting?)
Have machine shop, maybe go 70cc??? I think I want to go into it a little bit and see what’s up and then maybe send it off. I’d kinda like to get it right and try that before going ported but I reckon it would be more efficient, less time and $ to just send it off and make it snotty from the get go.
Also seems to have an issue with the throttle. Trigger clicks and feels like it slips in the handle, doesn’t push the rod far enough to open the carb all the way...but seems to open all the way with saw running...? Hard to tell...
I’m pretty isolated in the desert and only have my old 2050 and 395 to go off of for reference. Attitude of the shops I find is if it runs, it runs. I’d like to have someone with a test log that knows what they’re doing and what a given saw should cut like...I wanted a pro saw to go between them and got the 2159 for a good deal, then wished I’d gone with the “20cc rule” and gotten 70cc... but if I can get this one to run good for at least smaller stuff, I can man up and swing the 32” 395 for the bigger stuff, it’s fun if a workout. Did two trees a little over 20” with it yesterday. I mostly remove dead trees around town for fun/cleanup/firewood.
This should probably be another post...thinking about a 24” for the 395...and need to order some chains for my saws. Was gonna go with madsen’s, they seem cool and I think they have a twofer deal on loops. That’s unless someone here has a recommendation. Bailey’s is closer but have more of a warm fuzzy with madsen.
All input and advice welcome, thanks!
