People might think I'm crazy but you can make rings .However you will never find out how on any chainsaw site .British motor cycle sites are much more informative on things like that and quite honestly more informative on just about anything related to two cycle engines .
When I resleeved the Mac 125 engine I turned about a half a dozen rings out of tool steel and had them about half done before I found the rings from Mike Acres .Believe me the process is a pain in the buttocks involving a number of steps . First of all it's tool steel and anybody who has ever worked with this stuff will tell you it's not all that easy to machine .You have to make a honing sleeve and use lapping compound to get the final finish and they need to be slightly expanded and heat treated .Some place in the process you will need to use a surface grinder to cut the rings to thickness .One machine I do not own .
All that long drawn out thing said if Wiseco makes the piston it's a good chance they make the rings too .It's also a good chance they won't be cheap .
