PAST 2019 CT GTG May 18
11:38 PM
Jeff, I was very pleased with the way that saw ran. It is an Asian 660 with Cross P+C and some addl port work, including bridge ports. It is still on it's second tank of fuel!
I so wanted a 660 that ran like yours that I contacted your builder, but he does not want to do them any more … but he gave me some good advice. I don't think mine is as strong as yours, but it is close enough that it put a :) on my face!
The only OEM stuff on it are the piston pin bearing, clips, and the Elastostart pull cord.
Thus I dubbed it the Flying Tiger (with the airplane logo) after the WWII guys that served in China.
Redfin
Meh...
11:38 PM
Central Pa
if you want to peddle the Chinese clone saws then you have 3rd rate saws
I have a problem with the whole issue of those *frenching pieces of junk
It’s ok to use some aftermarket parts but to try to pass them off as real saws you are *frenched in the head
Easy there Sunshine.
malk315
Running Saws for Therapy
11:38 PM
Lancaster, MA
Buck we have a CS355T that stands in for the MS200T when we need it to and she does great. Got that on recommendation from Mason when I learned the Husky T540 stands for Temperamental 540... Stayed away from those.
I hear they respond to muffler mods well.
Sent from my XT1585 using Tapatalk
11:38 PM
NW CT
A good little port job, muff mod with a proper tune and that 355 will SURPRISE you! There is a small air box mod that I’m not convinced makes a noticeable difference. Don’t mess with the timing, any adjustment to the the ignition timing seems to have negative returns
