- 10:04 AM
- Dec 29, 2015
- Strong Island NY
Selling 10mm 044. All OEM
Slant fin KS jug with perfect plating.
New OEM:
10mm piston and rings/pin/clips
Bearings
Gasket and seal kit
New Winter HD filter
Saw will be fully gone through and reconditioned. All parts cleaned in the USC.
Cylinder has had squish and base cut to yield a squish of 19 thousand already with factory metal base gasket. They run very well this way, but I will also add full port job at additional cost if desired.
OEM Muffler will be Modded with side outlet and solid cover. The timing will be advanced.
I will add pics along the way.
$525 with stock cut jug, $650 ported fully plus shipping.
New OEM:
Bearings
Gasket and seal kit
