wcorey
- 3:35 AM
- Dec 11, 2015
- ma usa
A year or two ago I picked up the better part of a reasonably clean 066 saw-in-a-box that I've finally scrounged enough of the missing bits for and gotten around to putting it together.
The guy I got it from, got it along with a pile of other saw stuff and didn't have any history on it.
Has a red light tank and coil, looks to be a short case from what little I know about these. Has the little oval plug by the oil cap...
The case must be a replacement as the serial number pad is blank and the crank appears to be new judging by the unblemished finish on the small end bearing surface.
I didn't notice at the time but turned out the cylinder with it was an 064...
Had to replace the pto crank seal, the lip was flipped out/herniated in one spot from a bad install but the fw side 'looked' ok .
Well, it failed pressure & vac miserably and it was the fw side seal leaking like a sieve all the way around.
Turns out the seal is 15x22x4 and the crank is 13.5mm, close enough to look ok on casual inspection but obviously very little pressure on the seal lip.
Looked into getting a new seal and according to the ipl's the choice is either 15x22x4 or 13.5x20x4, of course I would need 13.5x22x4.
I can sleeve the seal pocket down to 20mm but would prefer to get the 'right' seal, if there is such a thing.
WTH kind of mutt do I have? Did they make a short case with a 22mm seal? Did someone bore this one out?
