Chainsaw Jim
Con Artist LLC
- 3:03 AM
- Feb 8, 2016
- Springfield Oregon
I'm thinking 394 muffler with a welded on flange. Not entirely sure yet.With a head and studs the bolting down would be real easy. Might have to weld up the exhaust flange to tap muffler bolts or use a 385 muffler and washers over the tubes to hold it on.
It depends on how much machining and welding needs done on any build. I've spent more time rebuilding some stock saws than I've spent on building a modded saw.Am curious ,how many man hours go into r&d on something like this build ? Doing it for a living a guy could go broke real fast if do too many ?
But this isn't a build for a work saw. This is going to be a build for the 6 cube racing class so it may be the only one I build.
I make my living running my shop on a normal scale and I work on these things in between jobs.
I'm going to shape it like I did this one so I can use any boot I want.Curious how your planning on running a boot with this setup?
