Pointer_1
I got a new (to me) 064 a while back that I just got around to messing with. Saw had new piston/rings, new carb kit, and port matched muffler. The guy I got it off said it ran great but he also lived in a very different elevation than myself. When I got it I just made sure it fired and then put it up, then life took over til now. It fired up but would't idle or run for more than a few seconds. I tuned the H and L all the way in and backed them off 1 1/4 turns each, and turned out the idle screw a bit. Saw would run now but not for more than 30 seconds. I turned the L screw out maybe another 1/8 of a turn. Started up and turned the idle back out a bit. Saw idles now, and continues to do so without shutting off. Put the tach on it. Idle is at around 2450-2600, chain is not moving. if I turn the idle back in it sounds like its going to die. Went wot a few times and it's around 12600.
However, there is a hesitation from idle when i give it some throttle. What should I be doing to get rid of this? How do the other numbers look? I know I need to get it in some wood to do this properly but this is just preliminary.
Sorry if this is basic, just my first time trying to fine tune.
