merc_man
merc_man
- 4:36 AM
- Feb 24, 2016
- southern ontario
Working on my uncles truck.
It had a fuel leak which is why i had to go get it. (Not running out of gas) get it home dump some gas in it cycle key bunch time and try starting. Bucks and fart and dies. Then nothing. Crank little more and nothing.
Crawed under truck to listen for fuel pump as my boy turned key on. Cant here any thing.
Pulled relay. Its a four pin. Found the ground then hot then signal. Fouth should be wire to the pump. Jump the constant power to where the wire to pump should be and still nothing. Cant here the pump at all.
What you think about making a hole in box to axcess the pump. Hes fine with it.
I know its not the propper way but the easyesy when i dont really have the time.
It will all be hidden under the box liner. Would have to unhook battery and put a few weld on it and silicone it after.
Whats your thoughts.
