Redfin
Meh...
- 12:32 PM
- Dec 24, 2015
- Central Pa
Randy, do the circlip installers work on most size clips?
I'm not real familiar with all the different sizes of clips but I'm guessing 10,12,13 mm? I've only ever used one of my digits and a pocket screwdriver. Would these clip installers work on other brands as well?Well Sir........
There is a tool for each size clip.
They are not cheap either.
Are the cylinders all the same size and type?
Chambers look a bit different.
Ya think?Jon just checked compression on one of these. 210.....
My gauge might need a new Shrader valve.
Well Sir........
It may jump a bit if tested at a lower elevationJon just checked compression on one of these. 210.....
I got this carburetor off ebay for 40$ shipped and it is fully adjustable made my 026 run perfect.So I may be jumping the gun alittle on this thread, but what carbs do you prefer on these? I have a very nice metal tagged red levered 026 that I wanted to add a 038 or 044 carb with velocity stack. I would make a backing plate just like a 044/46/64 and 66 have already. Is it worth doing these mods or can you achieve the same results out of lets say a wt194?View attachment 5598
That's what the saw wears now is a wt194, but like most of us know the filtration system is the down fall of these saw's!
buy a husqvarna then.That's what the saw wears now is a wt194, but like most of us know the filtration system is the down fall of these saw's!
545Do they make chainsaws? What one would you suggest?
