sawtalk81 Well-Known OPE Member Local time 2:44 PM User ID 10827 Joined Oct 28, 2019 Messages 79 Reaction score 120 Location California Nov 4, 2019 #1 can any expert chime in with the. true specs of. 026 bearings?
drf256 Dr. Richard Cranium GoldMember Local time 5:44 PM User ID 319 Joined Dec 29, 2015 Messages 9,334 Reaction score 61,422 Location Strong Island NY Nov 4, 2019 #2 What do you want to know exactly? The flywheel side is model specific. 16002? I’d have to check number. It’s a thinner 6202 bearing, same OD/ID but thinner. The PTO is a 6202 with the extended lip for the seal retention. Oem only unless you want a china knockoff. Same as 024-046. Last edited: Nov 5, 2019
sawtalk81 Well-Known OPE Member Local time 2:44 PM User ID 10827 Joined Oct 28, 2019 Messages 79 Reaction score 120 Location California Nov 7, 2019 #3 One bearing is. 15x35x13. part number 9523-003-426 . i believe pto side. The other part number is 9503-003-0320
sawtalk81 Well-Known OPE Member Local time 2:44 PM User ID 10827 Joined Oct 28, 2019 Messages 79 Reaction score 120 Location California Nov 7, 2019 #4 drf256 said: What do you want to know exactly? The flywheel side is model specific. 16002? I’d have to check number. It’s a thinner 6202 bearing, same OD/ID but thinner. The PTO is a 6202 with the extended lip for the seal retention. Oem only unless you want a china knockoff. Same as 024-046. Click to expand... You answered my thank you for the reply.
