FOUND IT 026-260 cylinder and parts
Cpedersen518
12:14 AM
Johnsonville ny
Looking for a good used cylinder. Decomp or non don't care. Need some tank handle parts too
lehman live edge slab
Live Action
11:14 PM
Mn
What you looking to give for them? I should have the a complete saw with loose pto end bearing.
Cpedersen518
12:14 AM
Johnsonville ny
I'm not sure what they go for . What's the price on the saw . I'd probably just take an 026 cylinder. What's the difference between 024-026? First stihl I've played with so I'm not sure
Live Action
11:14 PM
Mn
024 is smaller bore and stroke, 024 super smaller bore but same stroke as an 026. I think I have an 024 super single ring ks cylinder and a couple 026 cylinders also. No decomp on any and in my opinion unnessisary on anything that small.
Cpedersen518
12:14 AM
Johnsonville ny
I'm just looking for a good priced good looking stihl 026 cylinder. Will you have the parts for the handle I need ?. I'm not sure what's missing so probably on the handle
stihl_head1982
Here long time
12:14 AM
USA
The 024 super should be the same bore as the 026.
Yes the decomp is really not necessary -- perhaps unless you intend to port it (but not all agree on this facet either).
For some reason the decomp cylinders always seem to sell higher - not really sure why. I have some of these parts if the OP has not found them yet.
Send me a PM
Live Action
11:14 PM
Mn
These are the displacements, but I would agree that stihl most of the time make a super by adding bore size not stroke. This is one of the odd saws, and an 026 cylinder will fit on the 024 case if you grind case clearance for piston.
Cpedersen518
12:14 AM
Johnsonville ny
Its a 260 i got in a box I'm putting back together . Just trying to make it cut wood again
Live Action
11:14 PM
Mn
Well a 260 has flippy caps so if you use the 026 tank it will have one of each. Might want just the internal linkages if they will work. The cylinder will but I don’t know about throttle Parts fitting in a 260. And if the cylinder is toast then what caused it. I don’t have any ms260 stuff and it is slightly different than an 026 if I remember.
Cpedersen518
12:14 AM
Johnsonville ny
Cylinder is fine, got sacked with a tree or something. Just missing a few more fines then I feel safe with running . And I have it spit and in going right through it
Live Action
11:14 PM
Mn
Ok just wondering, I’ll send couple pics of different 026 cylinders.
Live Action
11:14 PM
Mn
  • I have at least two cylinders for an 026. One haws a decomp and the other doesn’t.
Live Action
11:14 PM
Mn
It should don’t think that changed, I’m thinking at least 50$ and shipping. Cylinder is nice I’ll send pics.
Live Action
11:14 PM
Mn
I have a piston also but for some reason the one I had with the jug didn’t stay together so might be out of a different saw. I’d probably re ring it.
