ShaggyClyde
OPE Member
Is there a big bore kit available for an 025 or is there other piston options if i bore the 025 cylinder to fit a bigger saws piston.
I've not heard of anyone doing this before, but it's not a model I deal with regularly so I'll wait for others to chip in
Edit: I see it's your first post so not sure if you're taking the piss or not, but probably best upgrading to a pro saw such as an 026 first, then if you're still hungry for power send it to randy or a number of other porting gurus over your side of the pond to be properly brought to life
No. Most AM chainsaw big bore kits perform poorer than their oem standard bore counterparts due to the transfers being smaller. You would end up with the same issue boring out your cylinder. Also you would need to have it replated. By the time you are done, you will have more money in it than a ported pro saw.
Is your cylinder damaged?
You can also give the timing a bump,
Welcome to OPE!
You'll need to file the cast-in-flywheel crank key. Take about .025 off of the left side as you view it from behind the flywheel. Then you will be able to rotate the flywheel counter clockwise when you install it. You should feel it's ability to rotate a bit when it's seated on the crank snout.how do i go about doing that once i get it running?
