- 5:28 AM
- Jan 14, 2016
- North western Ohio
Now here is one for you .Kevin( cut for fun )had I think a Sachs 166 ,big old dude that he was having a problem I think with coming up with something to remove the clutch .I had the brain storm of what basically was a pin spanner .I used hardened dowel pins but they didn't gain enough purchase .Kevin replaced them with a piece from a square shaft screw driver also hard steel .Worked like a charm plus proved sometimes two heads are better than one .Never say die .
